The same possibilities in tube connection with sandwich plates
In the Connection Vault there are with the tube connections 5 connections with sandwich plates.
By these connections there are two groups with different possibilities.
Group 1:
- Tube connection with sandwich plates - additional object
- Tube connection middle with sandwich plates
Group 2:
- Tube connection with sandwich plates - 2 diagonals
- Tube connection with sandwich plates - 3 diagonals
Basically all these connections should be immediately programmed and have the same possibilities.
Unfortunately, the possibility is absent in group 1 to be able to set the plating end of the tab plates.
There is this possibility only in group 2.
Indeed, the cover plates and slots are programmed in group 2 faultily.
The cover plates are generated as a polygon ale plates. Therefore the output is corrupt in the drawings.
If one has entered a gap in the slots and the slots have a round end, the slots are not usable and must be changed by hand.
We have already informed of these both errors Autodesk and we hope that they are soon repaired.
Idee einsenden
