Lot/phase token in all BOM lists
It would be nice that there wil be a lot/phase token available in every bom list.
Now it is only possible to get a lot/phase in a structrual lists (with the groupheaders) and not in partlists.
I think this is strange., when i want to order my material in a materiallist i must have the possibility to order it per phase.
regards
6 Comments
Bogdan.O
can you tell me what the status is . A lot of customers are asking this.
Julio_Soto
this would be very useful
james.alvarado
Observer
Hello Did you find a solution for this?
Matrix-Software
No i am sorry, there is no solution found
Garret_H
I found a workaround at least.
Use model browser to add your lot/phases to the "free remark" column.  You can add a little extra description there if you'd like.   The external BOM lists will at least pull data from there.
The various user attributes are also available.
More effort adding it twice and will require to verify the data, but at least it's there and you don't have to pull code from the UK build.
