Live Cut / Section Views
Cut / Section arrows to be live and linked to the cut view once created.
This will allow for dynamically moving, resizing cuts and cut depth after placement via grip points or similar.
The view created by the cut will also be able to be resized by corner grip points.
This would be very handy on GA drawings and large assemblies (all drawings)
1 Comment
daniel.orchardYBVSY
It would also be great if the live section/cut views as above can be moved between drawings (Between drawings for GA / Marking / Erection drawings or between sheets for multi sheet assemblies - 1 file with multiple sheets) and retain the live link and resizing grips as per the above.
