If i create a stair with a connection "stair anchor base plate" it could be that the second bolt of the Tread will be in a other beam than the stringer (see attachement). If this is the situation the nc dstv file will give an error, because a hole is outside the stringer.
It would be nice to have an option to ignore the second bolt before create the nc file, without having to delete a connection or macro.
regards
