Joints with 2 or 3 diagonals - options to set different bolts for each diagonal
When create the current bracing joints for 2 or 3 diagonals, you set identical bolt parameters for all bracings - diameter, type, norm, grade.
In case the efforts in diagonals are very different, you might need to use different bolt diameters.
The feature request is to be able to set different bolt parameters (especially diameter) for each diagonal for these joints:
  • Gusset plate for 2 diagonals
  • Gusset plate for 3 diagonals
  • Tube connection with sandwich plates - 2 diagonals
  • Tube connection with sandwich plates - 3 diagonals
  • Double tube brace gusset - 2 diagonals
  • Double tube brace gusset - 3 diagonals
Thank you very much.
Best regards,
Emy
1 Kommentar
haedicu
Status geändert in: Under Review
Idee einsenden
