Galvanisation holes in joints
in many joints the option is missing to paste galvanisation holes.
All joints should be checked to this problem and be complemented.
Regards
Elias
3 Comments
haedicu
Thank you for this idea, We will keep it for the moment as a tracked item for future Advance Steel versions.
Until then your customers can use the option to combine joint with manual holes creating a custom joint - but I'm sure this is known already on your side.
best regards
Udo
and please add the galvanazing holes with the option on the assembly drawing to not have dimensions at these holes.
this problem (wish)  is allready known in advancesteel version 10 Udo and still it is a future consideration. I will hope that Autodesk will change this soon. In the attached pictures you also can see that in joints where it is possible to get galvanisation holes , it is not working correct.
In a moment end plate connection for instance . I used the setting "2 holes centered" and then the values for "offset from end" are disabled automatically (grey in the dialog). This makes this setting useless most of the time because now galva holes are being drilled in the edge of the plate.
I will hope that autocad will not shift this problem to Advancesteel 2022.
regards
Carlo Heisterkamp
Carlo Heisterkamp2016-10-19 10_59_34-Autodesk AutoCAD 2017 - NOT FOR RESALE - [Drawing1.dwg].png2016-10-19 11_01_43-Advance Steel - NOT FOR RESALE   Moment End Plate.png
