Drawing Style for Cambered Beams on Assembly drawings
Currently there is no Assembly drawing style for cambered beams.
The single part style for cambered beams shows the camber exactly, if that camber position isnt central then there isnt a way of showing on the assembly where the camber goes.
Also it can be confusing for workshops where the single part shows and dimensions the camber and the assembly ignores it.
2 Comments
AntDrt
wow, what kind of sorcery is it ?
can you set a new drawing style for your assembly view (based on singlepart drawing), maybe it's just a problem in the drawing style UK ?
i've never seen that with french drawing style Smiley Indifferent
Flies-Eyes
Rob, how did you get the Curved beam show the beam outlines.  When I run mine it only shows the System line?  I tried running it on the UK databases and got the same result in that is only displays the system line.  Is there a MT setting to make it display the Standard outline?
