Default style for cut views & callouts: extra MT options for GA or shop drawings
When creating a cut view or a callout view, the default drawing style (view request) that I want to use will depend on whether the drawing is a General Arrangement (overview) or a shop drawing.
e.g. I will not want single part labels on a GA but will do so on a shop drawing.
I therefore suggest that the MT defaults for the Default view requests for cut view and callout views are expanded so that we can set different defaults for GA drawings or shop drawings.
3 Comments
It would be such an easy way, if we could decide the used detailstyle by clicking a palettebutton.
Maybe an extra category or an extra palette. Then having the choice to have a category for cut views and call out, by using the button in the category "CallOut", the command for callout should be startet with the selected detail style.
I create an example for it, but I think it should be done by the development
This palette for drawings could also have a more categories, maybe for bom on drawing or command which are often used for example insert label or dimension.
Pic:
Video:
https://autode.sk/2PrwcLh
additional, the solution would be to have the command for the direct key of the detailstyle.
We tried it a few times, but with no result, maybe someone have a trick
only for your interest, this was working in old versions. we tested it and we could use the directkey for the detailstyle.
