Volume Token
Volume Token
Add a Volume Token to AS that can be used in custom BOM Templates within assembly drawings.
This should be the exact volume excluding features etc.
1 Kommentar
You could use the exact weight and divide it by the density, this should be the exact volume or not?
I know from your thread, that this is not working for concrete, but for all other objects, this should work
Idee einsenden
