Show only
Search instead for
The annoying thing is in the image the SHS that the connection is attached to was not rotated or mirrored, it was copied using transform elements for all off them and starting from right to left the connections on the first half were all correct and the second half were all wrong?
It's probably because custom connections are based the beams ucs. I feel this would be a big change for AS to implement. I'm not hopeful. Prove me wrong AS!
I get that it is based on the UCS but all of my SHS columns were copied from one and not rotated or mirrored so why would half be OK and the other half be rotated?🤔
