Select multiple in clash check window
Hello devs,
It would be helpful if we could select multiple rows in clash results. Sometimes there are a lot of clashes that do not matter to user. I'd like to select multiple clashes and ignore those at once. Right now I have to manually select a clash and press igore clash button multiple times to make clash list clear. Please consider it in future releases of AS.
Thank you
Przemysław
1 Kommentar
TvdH1981
Hi, also  let us put a value in mm/inches that it will check for clasches. Now it checks on area. This is horrible. SOmetimes a clash is there for 1mm. We ignore this. Let us put clash values in mm and not area.
Idee einsenden
