Mutli user Concept in Advanced steel
We are facing issues with multi user option advanced steel to in a shared environment. When we check in all the elements from the slave model into master model we cant access or modify any of the elements.  After checking out the elements from the master model and try to modify the elements in the slave model we are getting this error: cannot mark objects as checked out. (we use partial check in and keep check out objects option )
kindly find the attached image for your reference and let us know the solution and correct steps or procedure to be followed to use this multi user option in advanced steel.
Idee einsenden
