Correct orientation of countersunk holes in part drawings.
AS generates its part dgns based on the part's own coordinate system that doesn’t recognize csk directions.
Drawings issued to the workshop aren’t clear which direction the csk is. The only way I can see atm is to manually check and re-orientate all parts with csk holes to illustrate them correctly on the parts dgns.
How about a management setting where the system always draws the face with the countersunk hole as the front face?
Or the option to flip to the opposite side of the part in it’s detail view box, similar to the way you can rotate the part by 90deg increments?
