Show only
Search instead for
Wenn man viel Treppengeländer zeichnen muss wäre das eine super Sache. Am besten so das man direkt auf der so erstelleten Treppe Geländer einfügen kann.Ohne Hilfsträger.
A group of us have been requesting that for the past 7 years. A work-around is the do the side profile of the concrete stair using either lines or polylines. Then create a polygonal slab to trace the profile. Change thickness to the width of the stair and you will have a set of concrete stairs. As for the balustrades, there is no automatic way to make them, but use similar concrete object to create them. Again, as a work-around. I have also used the 3D modeling to make them.
A concrete stair tool will definitely be helpful. In the meantime this video shows two ways to create concrete stairs and put railings on them using the railing macro and user connections.
In fact, if you use a concrete beam to make the satir (as in the upper stair in this video) you can place the railing macro directly on the concrete beam and use the Posts > Post > 1.Offset option to position it where you need. The raling post bases inside the Railing joint all place bolts not anchors so you likely need ot use User connections as I have.
If you use dummy beams to place the railing on, then setting the model role to Not Visible and the behaviour to not Use for Numbering and Use for Bill of Materials means the dummy beam will not show anywhere. In the UK build at least the Not Visible model role means GA drawings will not draw the object.
While we’re generally a fan of these ideas, the timing isn’t quite right for development consideration. As such, they are being put on the back burner to be re-visited at a later date. Please continue to comment and add your support.
