Clip angle connections with individual angle selection option?
A recent issue I worked through with Autodesk Technical Support got me thinking...
It would be very beneficial if the macro for clip angle connections were improved to allow individual selection of the angle size on each side of the connection and subsequently individual selection for the horizontal bolts set out at main for each angle.
Several times now I have run into the case where secondary beam 1 and secondary beam 2 axis lines are slightly offset, yet they still use a common bolt connection through the main beam.  This is generally done by using different size clip angles for each side (near side and far side) of a given secondary beam.
I believe properly set up this would also take care of the issue I have when I use a double angle connection and one secondary beam is symmetric (I beam) and the other is non symmetric (channel) but they use a common through bolt.  The current double angle macro does not calculate properly with the above scenario.
1 Comment
acbsdesign
Also-Very often the clips are shop attached to the main on ONE SIDE ONLY, and field bolted to the two secondary beams on the other side.
Custom connections do the job, but it has to be available in out of the box the macro.
