Multi User: Check In selected objects into Master model
Currently, when use the “Check in” function, ALL the check out objects are sent to the Master model.
This is very time consuming when you want to send back only one or few elements, to be available for your colleague.
It is particularly difficult when work on bigger models, because then you have to go again through the process of Search & Selection the elements you are working on.
The feature request would be to have an additional option to check in only the selected objects into the master model, while the rest of objects remain check out.
Thank you very much
Emy
3 Kommentare
Nicht anwendbar
It would be a great feature that will increase the speed in multiuser mode by leap and bound.
krnavek
Yes, this feature is asked for many years.
But the most important is the reliability and stability.
Nicht anwendbar
This is something really important, as it would also help to overcome the error/warning message "Checked Out object changed"...as like it now...the only way to get pass this error is to loose all work and do all over again, since last check out operation, re-building the connection to master model!
Idee einsenden
