clash check not by volume but by millimeters
What I like to suggest is that we can selct within Advance steel that we can select how to clash. What I want is to clach on how much mm the clash is.
So if a plate clashes with a beam 1mm it can be ignored. Or less than 3mm for example. Nu it is by volume and that is very anoying, because clashes as small as 0.01mm are reported. But this will always be ignored on the drawings.
So maybe you can help us out by making a buttom in the managemnet tools so we can fill in the amount of mm the clash must be ignored. For instance: all below 1mm or 3mm can be ignored.
