Additional sorting options / criterias for generating drawings
When generate drawings using a drawing process, the selected objects are sorted using a list of predefined options (rules). You can see these option in Drawing Process Manager - Selection/Arrangement order:
These rules are based on a very limited number of object properties (Position mark, Length, Thickness, Role, Weight, Class).
The feature request would be to have more options / sorting criterias, to control the order of my drawings:
- Name / Section name
- Material; Coating
- Lot/Phase
- User attribute
Thank you very much
Emy
3 Kommentare
ChristianBlei
Hi Emy,
the same is valid for marking parts. There should be more options to generate a more speaking sequence of the part marks, more common sense. It is not just data.....
Christian Blei
Austruct
Well said Christian.
Sorting items when numbering needs more user control.
DumitruBerteanu
Status geändert in: Accepted
Idee einsenden
