CAGED LADDER -Band extension compliance
Hi againSmiley Wink,
How do you control the length of the bands in caged ladders in Advance Steel?
I see that I can control the placement of the bolts from the Cage>Bands sub panel by putting in a value in 1. Gap, the bolt position changes, however the length of the band remains the same height.
I want the bolt at the specified location and have the length bands to comply with the rules.
Again, you can also change the position of the bolt from the Band connection panel but again the band does not comply with the rule.
As a work around, I use the Beam shorten feature extend the bands. This can be time consuming depending on how many bands you have.
It would be nice....
Please see short 40 second video for clarity
Best regards,
Janet
Graitec CANADA
