How to center the text in the grid bubble using Advance Steel 2018
Hi guys,
It's me againFrau (zwinkernd)
I had a client concerned about the placement of the text in the grid bubble. He noticed that the text was not centered as he would have them.
You are able to customize and adjust the text in Advance Steel 2018. The grid line text bubble can be modified from the Advance steel Management tools “Default” category.
Simply select the “Use filter” box and type ball in the field just below.
Expand the Drawing-Presentation category and then the “General” subcategory.
By default, Advance Steel settings for Balloon type is Rounded and 0'0" for the gap around balloon text  in the X and Y.
Change the Balloon type to Circle and the gap around balloon text  in the X and Y to 0' 0 1/4."
Furthermore, you can adjust the grid balloon radius.
Once the changes have been completed “Load settings in Advance” and back in the model” Update Defaults.”
I hope this helps
Video soon to be released on line!
Best regards,
Janet
GRAITEC CANADA
2 Kommentare
Nicht anwendbar
Great stuff!  Thank you Janet.
dcubbedge
This did not work for me.
Idee einsenden
