Bracing connection
Bracing connection
Is there a possibility to give a correct bracing connection to combi-profiles, such as double angles e.g. Now the first problem is, that only one of the two profiles is used for the plate dimension:
Second problem is that one of the bolt connection is not correct aligned:
Thank you!
1 Kommentar
Bogdan.O
Status geändert in: Archived
Thanks for taking the time to submit your idea and to everyone else for contributing your thoughts and votes.
Unfortunately, this idea could not be included on our road map and as such we will not be pursuing it in the near future.
Thank you for your understanding.
Idee einsenden
