Balloon detail
Balloon detail
It will be very helpfull if we had the balloon detail available in Advance similar to AutoCad Mechanical. -Enlarged portion of a detail view.
13 Comments
haedicu
Status changed to: Accepted
Thank you for this great idea. I agree that this will help producing cleaner drawing output.
We will take it in consideration for one of our next releases.
best regards
Udo
I totally agree, we are able to pull a section from an assembly or a GA drawing, it would be great to be able to pull a detail with all the appropriate text and Detail name.
Jonathan.Jasinski
On assemblies that have a specific area that is "complicated" a close up of just that area would be great.  A "Detail" view that is a much larger scale to show dimensions and features more clearly.  This would work similar to "Section View" but in a circle/polygon area.
haedicu
Riaan14
Why can't Advance Steel have the same detail call-out tool as Revit? I would like, if
I have generated for example a latticed truss detail, to add detail call-outs on the drawing
sheet at the gussets to create a detail view referenced to that call-out as one can do in Revit.
This will be very useful to use to generate referenced details allover AS.
That will be a huge upgrade for AS.
iwafb
These are the sort of ideas that save time (there are many more with future consideration status). Hoping they get implemented in the "near" future...
Creating the call out AND the Detail in a specified location would be even better. This has been a wish list item for awhile now.
haedicu
Status changed to: Gathering Support
IT-BaH
Hello!
We are missing an opportunity to add details out of existing views on workshop drawings.
Simillar to the way of making sections (_AstM4DetManualCut).
Example (created with AutoCAD):
hi,
i need a simple fonction that i can do a circle directly on drawing to have a detail view at another scale to see some detail better.
acbsdesign
y.belanger,
This was previously submitted, hopefully  we will get it implemented soon:
https://forums.autodesk.com/t5/advance-steel-ideas/balloon-detail/idi-p/5831706
Ilko Dimitrov
AntDrt
Hi done in V2018 of AS.
haedicu
