AutoCAD 3D Solids as "Special Parts" in Advance Steel need to Print Better!
Autocad 3d solids brought into Advance Steel as "Special Parts" do not print properly.
We need Advance Steel to remove the tessellation lines?
16 Comments
haedicu
Status changed to: Accepted
Thank you for this request. I agree that this will help creating clean drawings.
We will take it in consideration for one of our future releases.
best regards
Udo
FProcp
These drawings are just disgusting!
They are not presentable as professional drawings.
What is Autodesk thinking?
Plain AutoCAD can do it, Plant 3D can do it, but the super-duper Advance Steel cannot!
What is the point of being able to bring 3D solids in as special parts when they look this bad?
Is this a joke?
This is totally unacceptable!!!
Smiley Surprised
dean
I totally agree.  I have been struggling with this for awhile now and have had to redo an entire project because the drawings looked like crap.
Absolutely unacceptable.  I have made 3D solid sections for "buy out" items thinking this would work great (at least until I generated the drawings and saw what they looked like).  The last time I made 3D models of stock angle flanges for ducting and everything looked great in the model and then I generated drawings.  What a waste of time.  So, I had to go back and use a polyline to beam with an Advance Steel angle.  Drawings look good, BUT, now when copying an assembly (yes doing it correctly) and numbering the model, Advance decides it want to give "identical" assemblies different part numbers (thus the same assembly gets drawn several times instead of just once with a certain quantity).
I have talked to Graitec and have a case in with Autodesk, so we'll see what happens.
These two things have cost me a ton of time and need to be resolved immediately!!!
I agree, my drawings will not be accepted in my company looking like this
andrew.hnyluk
This is one of my top requests for the software, has there been any headway on this issue?
I Agree, This would be nice if this is sorted out. Because a know its a structural program, but we need to display somethings in context sometimes. Detail example between Cad And Advance Steel below
Advance SteelAdvance SteelAutocadAutocad
bill_justice
Apparently this is STILL an issue on the 2020 version. It baffles me that this program is having trouble drawing a circle.
tommyQD7G6
Still an issue with 2021...  Please fix this!!!
Teo1981
Observer
There are some news about this? It's totally incredible that an Autodesk product can't draw correctly an Autocad solid!!
Teo1981
Observer
There are some news about this? It's incredible that an Autodesk product can't draw an Autocad solid!!
No change in 2021 version. Is anything happening to fix this problem? I think this should be a priority!
AntDrt
no changes in AdvanceSteel 2022
@Gernot.Jeromin with advance steel focus on good looking drawings, does this will be enhanced soon ?
In this "page" you can see how Autodesk made $ billions on 2020 and every year they don't really make any real improvement in their softwares.
This is a clear example of an issue that users have been asking to be fixed since 2016 and they haven't fixed it.
Sorry to say this but it is very annoying to work with Autodesk , unfortunately they aren't more options out there because I guess Autodesk use their millions to buy the competitors.
This message probably will be reported or something. Let's see.
Sorry, but I need to change it to "Future Consideration".
We are aware about the request!
As said below: We will take it in consideration for a future release.
Gernot
johnC5ARB
This issued is a huge limitation of Advance Steel and should be rectified asap. In the 10 years I have been using Advance Steel there have been many occasions when I have said to my Clients "Sorry about the messy looking drawings but I am using Advance Steel". On occasion I have had to convert the model back to an Autocad Solids file so I can create a readable view, or explode a derived drawing and delete all the mess. Very time consuming!
John.
jasongTEMPD
Community Visitor
Hi Is there any solutions with regards to this issue
