When for example a beam has two endplates and a attached plates. and i create a assembly drawing with attached plates. The drawing consist a assembly picture and all attachedplates. If i move or copy or change something of the existing plates, the revision is going well, but if i add a new plate to the beam, the revision is going bad. I expect that the new plate will be added to the assembly drawing after an update, but it is not. IIt is added in the BOM list, it is added in the assemblydrawing itself, but there will not be a new picture of the new attached plate. If i delete the assemblydrawing in the document manager and create the column again, the new plate is added.
I think this has to be corrected. If something is working it has to work for the 100 % and not 80%.
In the screencast movie you will see what i mean.
regards
