Show only
Search instead for
I don't think your idea is logical. If we talk about steel structures in general, it is more than necessary to represent such lines completely (system lines in my opinion). Eg. from a static point of view, you need to know where such lines meet - which can also be in the area of the profile symbol, you mentioned above.
Not showing these lines has no benefits - in appearance, performance and function.
Thea reason for not showing the line through the symbol is for clarity purposes. If the column was rotated 90°, you would not be able to clearly see the hidden lines. The same thing would happen for angles, channels, etc.
Not showing the line through the widget is a common practice in the oil & gas/ Petro Chem industry.
