Any view using symbols
For any single line view using symbols the axis, median, single, etc. line should not go trough the symbol, it should stop on either side like so:
Also, allow users to set the gap of each member independently.
2 Comments
bigcarl5000kg
I don't think your idea is logical. If we talk about steel structures in general, it is more than necessary to represent such lines completely (system lines in my opinion). Eg. from a static point of view, you need to know where such lines meet - which can also be in the area of the profile symbol, you mentioned above.
Not showing these lines has no benefits - in appearance, performance and function.
Jonathan3891
Thea reason for not showing the line through the symbol is for clarity purposes. If the column was rotated 90°, you would not be able to clearly see the hidden lines. The same thing would happen for angles, channels, etc.
Not showing the line through the widget is a common practice in the oil & gas/ Petro Chem industry.
