Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
Angular dimension improvement
Currently placing angular dimension on details is not user friendly.
It will be much easier if we place angular dimesnions same way as in Autocad-by clicking only on the two lines, not making a few extra steps.
Ilko Dimitrov
7 Comments
haedicu
Thank you for this idea. I agree that this will help reduce time to clean up drawings.
We will take it in consideration for a future release.
best regards
Udo
THis will also make it more practical to place angle dimensions on plates with a radius bend, at present I create helper lines, dimension and delete, other times I just use the standard AutoCad dimension tool.
Julio_Soto
Coming up on 6 years for this seemingly simple and basic feature.
bigcarl5000kg
As we already know, important things will go idle for another 3 years and every 3 years it will be extended by the same period. Emergency has become a virtue.
IR8ASU1
I find that angular dimensions also tend to jump all over the place and change value when a detail is updated, even if the objects that the angular dimension are placed on have not changed, as per the attached image:
MetallPlanMerkinger
@haedicu after seven years, i think the Future is now! Time to implement!
bigcarl5000kg
wake up development team, we are here a pay so long for a huge of old problems ... good morning / good night ... a day has 24 hours ... on this planet
