adjustable running dimension symbol
I have seen on the forums and also on my own drawings where the running dimension symbol "RD" is not in the desired location, whether that be at a saw cut location or moved of the beam/column for some other reason. I would submit that the running dimension symbol when moved automatically adjusts the corresponding dimensions.
Idee einsenden
