Using the "preferred for manual dimension"(PFMD) snap point is a must when apply manual dimensions in advance steel. The improvement in the Snap tracking points is really good, but a bit of bug i think, that causes mayhem in the application of the dimensions.
When you start a session of AS, open a drawing to edit, you need to check the "PFMD" Snap option under the Snap options in the tray, but you have to go right into the settings dialog and set it, not from the shortcut menu, that pops up.
This is Ok, but the issue seems to be that is you do this it stays set for the session your are in, but then it reverts back if you start a new session.
Can this be fixed so that it does not reset each time you go into a new session, but recalls the settings.
Also users tend to use the shortcut pop up to set the PFMD Snap point, but when you do this it does not set the setting under the main snaps dialog, you must go into the main Snaps dialog, under the Steel Osnaps and select the PFMS check box. but as mention previously it does not stay set.
Can be a bit frustrating to recall to do these setting every session or new day etc.
