Additional Surface/Side Property of plates needed
Hi
Plates should have an optional property "surface" as graitings have. There are plates available that have two different sides. Because there is not surface or side property for plates that can be used in modelling and numbering, Parts that are not identical because of their side orientation may get get detected as identical in numbering and get the same number.
User shave to use workarounds like weldmarks that may cause that identical plates because of their weldmark position do not get the same number......
BR,
Christian Blei
5 Comments
Austruct
This would be great for harden surfaces/faces or liner plates in chutes.
haedicu
Thank you for sharing this idea with us. We will keep it in mind for any future improvement on document management in Advance Steel.
best regards
Udo
This is really an important function as there are many different types of plates, ones that need to be folded e.g. chequerplates, Alpolic panels, stainless steel polished sheet to name a few. It is not only the drawings that require extra special attention after creation it is the DXF files for laser cutting or processing that also have problems determining the top surface of the plate (as I have found out recently, picked up by customer before cutting a lot of chequerplate). I think this would be a useful switch to have similar to grating, in this case default is off and selected assign top surface.
niels.h
I don't know why this hasn't been addressed yet?
it's been 4 years and in the construction industry plate often requires different prep and finishes on each side.
MetallPlanMerkinger
@haedicu after seven years - Future is now! Time to implement!
