I recently got a detailing job which requires all beams to be connected to a column with a WT profile. but i cannot find it on the connection vault, any suggestions?
thanks
Do you have any more detail on this? Engineer Dwg or pdf showing the exact detail required?
This is the type of connection, a WT welded to a TS column. I can do Shear Clips and Clip Angles, but no option for this type of connection.
Its probably best to use a custom connection. I have attached a quick sample of one i have created,
