Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
WT connection
4 REPLIES 4
artpenadetailing
760 Views, 4 Replies
WT connection
artpenadetailing
I recently got a detailing job which requires all beams to be connected to a column with a WT profile. but i cannot find it on the connection vault, any suggestions?
thanks
WT connection
thanks
4 REPLIES 4
múinteoir
Do you have any more detail on this? Engineer Dwg or pdf showing the exact detail required?
The face of the BIM game | Former Autodesk Expert Elite | YouTuber | Lego Builder | Monaghan Man | Some Can, Some Cant
artpenadetailing
This is the type of connection, a WT welded to a TS column. I can do Shear Clips and Clip Angles, but no option for this type of connection.
wtheron
in reply to: artpenadetailing
wtheron
You can try to build custom connection, however that may be difficult. You could also model this connection manually.
múinteoir
in reply to: wtheron
múinteoir
Its probably best to use a custom connection. I have attached a quick sample of one i have created,
