I want connect two folded beams with bolts. It always insert bolt on top green flange or on bottom magenta flange, or through all flanges. What could I be doing wrong that I can`t get bolt in right position?
Usually I fix those problems with change of UCS position and clicking on "invert" and "finish calculation at gap", but in this case it doest giver right bolt position.
Solved by Sebastian_Eiche. Go to Solution.
A little bit tricky but.
ladys...there's an easy way:
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
Sebastian Eiche
I think I know what you are going to say, I always forget about this.
That˙s it! Thanks.
