Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
Wrong assembly lenght on drawings and lists
9 REPLIES 9
Message 1 of 10
lipskiszymon
498 Views, 9 Replies
Hi, I have the problem with wrong assembly lenght on drawing and list?
Have you any idea how to solve it?
9 REPLIES 9
Message 2 of 10
Hi @lipskiszymon,
I can't open you dwg (new format), is the description about the length of the MP or another token?
+++ impossible immediately and miracles within 3 days +++
+++ the only constant is the change +++ stay tuned for more +++
+++ since 03/2023 is Advance Steel in maintenance mode, no further development +++
Message 3 of 10
Szymonlip
in reply to: lipskiszymon
Description is about total assembly lenght:
The same is on the lists generated by default BOM Templates.
I have saved the files in 2010 version.
Message 4 of 10
Hi @Szymonlip,
you can't save Advance Steel DWG as older format, because of core version. I can't open 2023 data in my 2022 AS version, I can't help you, sorry.
Message 5 of 10
Hi all,
have a look in Management tools / Defaults  - there is setting for "Method for determining the dimensions of a main part structure" or something similar (here at German) - you have 3 possibilities to get the main part dimensions
Check the results, maybe this can help you.
Message 6 of 10
s_hannemann
shipping list looks the same on my computer. Every dimension seems to have a few mm tolerance. Couldnt find any mistake in your model. Looks like it is a hidden database entry or something like that.
Message 7 of 10
It seams that changing to option no 2 gives expected values.
I dont know if it is ok for every case... but here it works.
Thanks.
Message 8 of 10
Hi @lipskiszymon ,
2nd choice is a standard in my company
test it on a few cases and you'll see
Message 9 of 10
Hi @lipskiszymon,
could you test it on vice main parts? With what results?
Message 10 of 10
lipskiszymon
Hi, yes it works for main parts. Thanks.
