- Mute
- Permalink
- Report
Hi, I have the problem with wrong assembly lenght on drawing and list?
Have you any idea how to solve it?
Link copied
Hi @lipskiszymon,
I can't open you dwg (new format), is the description about the length of the MP or another token?
Description is about total assembly lenght:
The same is on the lists generated by default BOM Templates.
I have saved the files in 2010 version.
Hi @Szymonlip,
you can't save Advance Steel DWG as older format, because of core version. I can't open 2023 data in my 2022 AS version, I can't help you, sorry.
Hi all,
have a look in Management tools / Defaults - there is setting for "Method for determining the dimensions of a main part structure" or something similar (here at German) - you have 3 possibilities to get the main part dimensions
Check the results, maybe this can help you.
shipping list looks the same on my computer. Every dimension seems to have a few mm tolerance. Couldnt find any mistake in your model. Looks like it is a hidden database entry or something like that.
It seams that changing to option no 2 gives expected values.
I dont know if it is ok for every case... but here it works.
Thanks.
Hi @lipskiszymon ,
2nd choice is a standard in my company
test it on a few cases and you'll see
Hi @lipskiszymon,
could you test it on vice main parts? With what results?
Hi, yes it works for main parts. Thanks.
