Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
Wild green assembly frames
20 REPLIES 20
Message 1 of 21
muleman1
795 Views, 20 Replies
This is a screencast of out of the box AS2023 assembly drawings. I'm sure I have done something really bad to create this and would like to avoid in the future, if someone was kind enough to tell me my error.  maybe @DumitruBerteanu  @AleckGiles
https://screencast.autodesk.com/Main/Details/a3f5849e-00cc-4d5f-8660-c4467442d528
....How easy it is to acquire knowledge, yet how difficult and painstaking is the process of gaining wisdom. .... Chuck Swindoll
20 REPLIES 20
Message 2 of 21
Ignus.E
in reply to: muleman1
Hi, I did not run the any drawings on this model, but i would start to look at why if you zoom extends the model disappears in the distance. That tells me there is something else that probably should not be there. Try to find that or copy the model into in new project and test again
Message 3 of 21
muleman1
in reply to: Ignus.E
So I ran some checks and found a random 18" system line that weighed "negative 231256 pounds"  ???? got rid of that, now "no errors" but still wierd results....
Message 4 of 21
acbsdesign
@muleman1
Did you purge? Any negative lengths leftovers in model?
It happened while ago (AS2020) and it turned out to be a ghost element with negative length, far far away in the model. Found it, deleted it, purged and it fixed the model.
If this information was helpful, please use the Accept as Solution function, this makes it easier for other users.
Ilko Dimitrov, IDC-1, M. Eng.
Tekla and Advance Steel Detailer
ACBS Structural Steel Detailing
If it is made of steel, I can model it and detail it.
acbs-usa.com | Helpful Place
Message 5 of 21
muleman1
in reply to: acbsdesign
Message 6 of 21
Ignus.E
Have you tried Audit yet? And does it behave the same if you just copy the elements into a new project with window selected elements?
Message 7 of 21
muleman1
My saga continues... fortunately I am able to work around this issue, though it is time consuming. I have another screenshot that may contain a clue, notice the X value in the screenshot below..
Message 8 of 21
acbsdesign
@muleman1
Can you make a screenshot of model browser, sort by length, any lengths with negative values?
Message 9 of 21
AleckGiles
As others have mentioned, doing a zoom extents on your model goes to galaxy level. This is indicative of issues in the file. This includes parts or elements at rediculous coordinates or with nonsensical properties. Autodesk have published this helpful FAQ on fixing the zoom extents issue. Make sure you have completed ALL these steps and the zoom extents is working correctly before doing anything else.
Then update or recreate your drawings and see if they make any better sense.
Aleck Giles, Structures Consultant, Graitec
LinkedIn
Message 10 of 21
muleman1
in reply to: AleckGiles
Good morning. Thanks to everyone for their help. I could not even attempt AS without the help of the forum gurus !!
I ran all the suggested tips and checks. I did receive better results, though not ideal. Its not in video, but "zoom all" functions as it should. Please see screencast for results. I apologize for the video length, but it was the only way I could think of conveying the results.
I had linked wrong screencast, it is correct now.
https://knowledge.autodesk.com/community/screencast/c171c82c-8295-4d6f-b434-8dd59ad7a9b1
Message 11 of 21
acbsdesign
@muleman1
Please add the Length column in Model Browser, you don't have it currently.
Sort per length and take a screenshot.
Message 12 of 21
muleman1
Message 13 of 21
acbsdesign
@muleman1
Click on Length on top and sort so the shortest length is on top and make a screenshot.
Message 14 of 21
muleman1
Message 15 of 21
acbsdesign
@muleman1
So no negative lengths...then some double feature, cut, shortening.
The 1/16" square bars-anything suspicious with them?
Message 16 of 21
muleman1
When I get back to my machine, I'll seach again, but so far all my searches come back normal, ie "no errors", "nothing to purge", etc.... As for those 1/16" bars, I have no idea where they came from. I assume the macro generated them for whatever reason...  All this said, I am far, far from expert and we have no real reseller help, so a GIANT thanks to all who try to help us!!!!!!! We appreciate it beyond measure!!!!!!
Message 17 of 21
Sebastian_Eiche
could you upload the model? it would be easier to have a direct view on it
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
Message 18 of 21
muleman1
in reply to: Sebastian_Eiche
@Sebastian_Eiche thanks for looking. The orignal drawing is atttached to my 1st post. If you need the modified one I've been trying to fix with all the suggestions, it will be late afternoon be fore I get to my office to upload it,
Message 19 of 21
Sebastian_Eiche
correct...I didn't recognize it 😃
Sebastian Eiche
Message 20 of 21
Sebastian_Eiche
I have short view. The problem is cause of the "long railing" not sure why. I tested it by deleting the objects and use "zoom all".
in my video you see, I just select the grip point, move it a bit and move it back. With this routine, the railling will be "recreated" and after this...no problem.
Also the detail drawing has no bit green frame.
screencast: https://autode.sk/3OEUfW0
Sebastian Eiche
