how can I increase weld symbol size or text size, i've changed every setting but no chznge please help me in this
Go to> Management tools> defaults> use filter> type weld size> expand drawing presentation> click on general> change weld size. I didn't test this so if it doesn't work i appologize
If you are working with Advance Steel (AS) 2016 version, the weld symbol definition (size, text ...) is set in the file WeldTemplate.dwg, located here:
You can modify here the entire configuration of the weld symbol.
Some important notes / remarks:
You can find more and detailed information in these FAQs:
I hope these will be helpful for you.
Best regards,
Emy
