After connecting parts together with the weld line object, how do you get them to display not just the weld size but also the length. I have only been able to show the weld size thus far. Is there another weld symbol I need to use? If I need to weld a 1/4" fillet for 4", how do I get the symbol to show this. It seams like this should be really basic, but I can't seam to get advance steel to show the weld symbol with the length.
Solved by DumitruBerteanu. Go to Solution.
Unfortunately the weld length parameter from the weld object can't be displayed on drawings through the Advance Steel weld symbol. The symbol doesn't have any avaliable tokens that can be configured to display the length. We're considering this for a future improvment in the Advance Steel weld symbols.
