I like the "create callout view" command, works like a charm EXCEPT if you have two callout views on a sheet emanating from two different views, you get two details LABELED EXACTLY THE SAME!!! C'mon developers, give us a way to edit the bloody text!!!
Solved by Sebastian_Eiche. Go to Solution.
do you mean the naming of the callout? This is a default "unique cut view names in the drawing sheet" but then the cutviews are also named like this. I'm not sure if you mean this...your post maybe need a picture.
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
Sebastian Eiche
attached is my drawing.
This is the default I wrote, but as I wrote this is for the cut views too.
Sebastian Eiche
Sebastian Eiche
Thank you Seb.
I'm a bit frustrated today by AS2019.....hence my 'attitude'. I could have sworn that I had that box checked, but it wasn't.
Thank you Seb.
All is fine, I know these days. But I think in these days it's important to use the forum. In this situations the things which often are not work as expected and normally will be accepted should be publish. And often these ''accepted" behaviours get a solution by another user.
Sebastian Eiche
Sebastian Eiche
New job, new day. Unique box is checked in "MT Defaults". I have one GA drawing with two callout views. Both are labeled "Detail A".
UPDATE: Deleting the detail and recreating it gave me Detail B.
But, why??? At this point, I don't care, just want to get this job out the door!
