Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
Profile Weight Adjustment
5 REPLIES 5
markhubrich
389 Views, 5 Replies
markhubrich
Can anyone tell me where I can find a reference for the profile parameter value meanings?
I copied a profile to create another. Everything is fine except the weight. I created a 1 foot length and checked it's properties. The mill certs I have say that this material should be 138.1 lb/ft.
So now I realize it probably calculates the weight based on surface area and values from whatever material grade I select.
I created this grade with values from A500-gr.B. I assume the Density is what I need to change but what exactly does that value represent?
...and fix the kiss export issues.
5 REPLIES 5
markhubrich
in reply to: markhubrich
markhubrich
I trial & error tuned it but I would still like to know what exactly that density value means.
Sebastian_Eiche
The density is value which is set from the material. The density multiplied with the volume is the weight.
Nothing software special it is pure physics 😁
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
Sebastian Eiche
markhubrich
I guess this is why I'm confused...
What does the 4.54 actually represent?
I believe the density value (the 4.54 value) is in ounces per cubic inch.
markhubrich
markhubrich
Thanks!!
Thanks!!
