TUBE MITER WELDS
TUBE MITER WELDS
FCort
TUBE MITER WELDS
FCort
Hi all,
From your experience, which weld symbol applies better to a miter steel connection of rectangular tubes?
HSS8x2x1/4 frame, AWS D1.1 prequalified welds CJP.
bigcarl5000kg
example from Google for a standard weld:
https://images.app.goo.gl/7FQtLc6HWBsac4fL6
+++ impossible immediately and miracles within 3 days +++
+++ the only constant is the change +++ stay tuned for more +++
+++ since 03/2023 is Advance Steel in maintenance mode, no further development +++
FCort
Thank you for the response, but that image is not a prequalified weld CJP.
j.hamelin
At first, for a CJP on any hollow tube you need a backing plate.
Then you must specify the effective throat and the weld size.
So you can use something like this :
Advice : Don't put any symbol you don't fully understand before asking your welding sup/ing to back up your... mind!
Mechanical Design Drafter
If this information was helpful, please use the Accept as Solution function, this make it easier for other users.
FCort
Thank you for the response; just one comment, on CJP, the weld symbol shouldn't indicate the depth of the grove/weld, CJP implies that the weld metal extends through the joint thickness.
j.hamelin
@FCort
It's seems you already know what you looking for so... was this a test?
FYI effective throat can be more than materials thickness if you ask for a convex finish.
FCort
It was not a test; this is a forum. It is better to clarify any doubt so everyone can gather the best information to reduce misinterpretations or mistakes.
Thanks for the reply.
