Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
TUBE MITER WELDS
6 REPLIES 6
FCort
506 Views, 6 Replies
TUBE MITER WELDS
FCort
Hi all,
From your experience, which weld symbol applies better to a miter steel connection of rectangular tubes?
HSS8x2x1/4 frame, AWS D1.1 prequalified welds CJP.
TUBE MITER WELDS
Hi all,
6 REPLIES 6
bigcarl5000kg
in reply to: FCort
bigcarl5000kg
example from Google for a standard weld:
https://images.app.goo.gl/7FQtLc6HWBsac4fL6
+++ impossible immediately and miracles within 3 days +++
+++ the only constant is the change +++ stay tuned for more +++
+++ since 03/2023 is Advance Steel in maintenance mode, no further development +++
FCort
in reply to: bigcarl5000kg
FCort
Thank you for the response, but that image is not a prequalified weld CJP.
j.hamelin
in reply to: FCort
j.hamelin
At first, for a CJP on any hollow tube you need a backing plate.
Then you must specify the effective throat and the weld size.
So you can use something like this :
Advice : Don't put any symbol you don't fully understand before asking your welding sup/ing to back up your... mind!
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
FCort
in reply to: j.hamelin
FCort
Thank you for the response; just one comment, on CJP, the weld symbol shouldn't indicate the depth of the grove/weld, CJP implies that the weld metal extends through the joint thickness.
j.hamelin
in reply to: FCort
j.hamelin
@FCort
It's seems you already know what you looking for so... was this a test?
FYI effective throat can be more than materials thickness if you ask for a convex finish.
@FCort
FCort
FCort
It was not a test; this is a forum. It is better to clarify any doubt so everyone can gather the best information to reduce misinterpretations or mistakes.
Thanks for the reply.
