Tube end plate connection
Nicht anwendbar
479Aufrufe
2Antworten
Nachricht 1 von 3
Nicht anwendbar
Hi Guys! I have here the end plate connection for the tube that cannot be the same size as the tube, the end plate is shorter than the tube. Please help on how the end plate be the same size as the tube to fully cover it, Thanks in advanceUntitled.pngUntitled2.png
0 „Gefällt mir“-Angaben
480Aufrufe
2Antworten
Antworten (2)
Nachricht 2 von 3
Karsten_Bork
could you please send me the model with connection?
It's easier for me to help in this case.
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
Karsten Bork
Mensch und Maschine acadGraph GmbH
Nachricht 3 von 3
AleckGiles
To get the end plate the same size as your tube you must set the "6. Edge distance" value on the "Bolt Layout" page of the joint properties. Then, f you want the plate on the main beam to be narrower set projection 1, 2 and 3  on the Gusset parameters page to a negative value (keep 2 and 3 equal or the shape goes weird).
Aleck Giles, Structures Consultant, Graitec
LinkedIn
Autodesk Certified Instructor - Gold
