Bolt Display Type - Retrospective change for ALL bolts in a model...
Totec_MW
Message 1 of 9
Totec_MW
Thank you all for your continued help with this AS newbie!
My next question; Is there a way to 'quickly' make a retrospective change to the bolt display type for an existing model? Only now am I starting to produce bigger more complex models, and only now am I realising how slow and laggy orbiting and panning can get with large models. One suggestion I have seen to help remedy this is to change the display type for bolts from Solid to Standard. Is there a way to do this in one hit, much like a LOD change in Revit? Going into each and every set of bolts and changing them manually is really not a practical solution for a large model with hundreds of joints.
I have already changed the display setting in my Management Tools defaults to avoid the issue in the future, but it would be nice to know if I can quickly switch. TIA for your help.
Replies (8)
Message 2 of 9
mick-CNF
Highlight one bolt, move cursor, right click mouse to select similar, right click mouse again to advance properties,  select display type and then standard.
If any are left repeat the process until all have changed.
If this information solves your problem please accept as a solution.
Message 3 of 9
Sebastian_Eiche
you could use the tool palette-  category filter: screws--then use the right click and choose Advance properties.
You could also select all Advance elements and use the Multi Edit
or you could create a command for this:
^C^C_AstM4SelectObjectByName ASTSCREWBOLTPATTERN _AstM4SwitchReprMode exact
This will select all bolts and change the display type to solid
Screencast: https://autode.sk/2PzWpq1
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
Message 4 of 9
alickomay
hi Sebastian
how do u get the "my own" part in AS tool palette
Message 5 of 9
Sebastian_Eiche
long right mouse click on a category icon
Sebastian Eiche
Message 6 of 9
alickomay
thanks i got a new  category now (my own)
but i dont have a blank button to customize  like wot was in your screen cast
Message 7 of 9
Sebastian_Eiche
it is not possible to create a new button if there's no button where you could make a "right click"
So make the following steps:
  • use a category which is existing for example "quick views"
  • make a right mouse on a command button, so you are in the "editing mode"
  • now change to you category and you should have the Editing mode here too
  • or you create a command in another category and move by drag 'n drop your category
Sebastian Eiche
Message 8 of 9
alickomay
that worked  thank you
Message 9 of 9
Totec_MW
Thank you both for your solutions. Very helpful, and I've also now learnt an extra feature with the customising of panels. Bonus!
