Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
Transferring commands!
4 REPLIES 4
pera3dcad
288 Views, 4 Replies
4 REPLIES 4
Dias_Antonio
in reply to: pera3dcad
Dear @pera3dcad
The Advance Steel Palettes are stored in a folder. Try to find this folder according to your version.
Let´s take as example, for Advance Steel 2021 version.
C:\ProgramData\Autodesk\Advance Steel 2021\INT\ASSettings_User.xml
Copy the entire folder with your new commands and paste it in the another computer...
Hope it works
- Marque "Aceitar como Solução", caso tenha resolvido seu problema.
- Select "Accept as Solution", if it has soplved the problem.
- Clique em "Curtir" se a resposta ajudou.
- Click on "like" if the answer helped.
Antonio Dias
|Linkedin|Instagram|Facebook|Twitter|YouTube|
Colaborador da Comunidade de Usuários Autodesk Brasil
pera3dcad
in reply to: Dias_Antonio
Thanks for the answer.
This helps me a lot.
I appreciate your advice, thanks for your time.
Have a nice day.
AleckGiles
HI,
If you want to clone the entire Advance Steel setup to another PC you can see my blog here for instructions. You should create a Master Data set from your main PC anyway to keep as a backup. Then if anything goes wrong or you need a new PC you can restore your setup in seconds.
Aleck Giles, Structures Consultant, Graitec
LinkedIn
pera3dcad
in reply to: AleckGiles
thanks for your reply.
I'll take a look, it's interesting.
have a nice day
