Can anyone explain why when using threaded holes the hole size in the model is correct for tapping when using the SET type bolt but when you create the drawing the holes measure to the bolt size?
Is there a way to get the holes to display the diameter and label correctly and also is it possible to set a different solid hatch colour for threaded holes other than altering them manually in the 2D drawing?
Thanks.
Solved by Sebastian_Eiche. Go to Solution.
Hi @mick-CNF
the threaded holes are labeled with their hole diameter if you want to have the tappered diameter, you could use the token "head diameter" sounds wired but works:
If you want to have an other symbol for it (which is often done by us too), you could use this AKN
I think you will get the result it's not so hard to realize
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
Hi Sebastian,
Thanks for that, exactly what I need, I will be experimenting now.
How do I get the label tapping size to a decimal place?
It is correct in the label box when adding the token but not in the drawing to any decimal place.
Thanks.
it a setting for the labeling:
But then all labels are created with this. You could also use the other way: doing it like this AKN article (should work, but I didn't try), I used it for single labels like the description in this thread
Sebastian Eiche
Mick............good afternoon
Did you ever achieve the representation you wanted
Ideally I would like something like this:-
The line in AstorBase - Symbols looks like this
But I can't figure out what I'm missing.........any help would be appreciated
thanks
Hi, the line seems to be correct.
Could you upload your file? I would try it on my system (which version and language do you use?)
Sebastian Eiche
Your symbol is working, if the other symbols are not existing or uses another diameter.
But if there's a line called hole_Any_Any_ToBo_ AS will use this symbol.
I tried it to give the Any_any line a diamter and the result is working:
I'm not sure if this is maybe a bug in the AS2021 version, I will try it in a newer one
Sebastian Eiche
I'm a bit of the same opinion..........I think it must be a bug in 2021
thanks for looking though Seb.......much appreciated
