STEP FORMAT
STEP FORMAT
Message 1 of 12
STEP FORMAT
Good morning,
Anybody could move this file from .dwg to .step, please?
It is very important!!
Thanks!!
Replies (11)
Message 2 of 12
múinteoir
Use the Export to CIS/2 format to create a .stp file
Múinteoir
The face of the BIM game | Former Autodesk Expert Elite | YouTuber | Lego Builder | Monaghan Man | Some Can, Some Cant
Message 3 of 12
I have just done it and when I open it with Catia V5, It does not work...
Where is the problem?
Message 4 of 12
múinteoir
Have you numbered the project?
Múinteoir
Message 5 of 12
I don´t know what is that... Explain me please.
Message 6 of 12
múinteoir
I think you need the objects numbered prior to export.
Múinteoir
Message 7 of 12
It doesn´t work...
Message 8 of 12
múinteoir
tested both files and all exports correctly to .stp
Múinteoir
Message 9 of 12
alickomay
i see on catia web site ther a few formates it can open
i exploded to acis solids  then file/exported to  stl an iges
i could not open that step file in autocad
but it wont let me upload iges  as its 98MB
the stl is .5MB
Message 10 of 12
AleckGiles
I believe that CIS/2 and STEP files are quite different despite sharing the same file extension (not clever by whoever defined CIS/2). Normal Advance Steel on AutoCAD cannot export STEP files. You need an AutoCAD vertical to do that. I haven't tried the 2019 specialised toolsets.
After exploding all your model to plain 3D Solids try exporting as ACIS (*.sat) file instead. I am sure Catia can read those.
Aleck Giles, Structures Consultant, Graitec
LinkedIn
Autodesk Certified Instructor - Gold
Message 11 of 12
IR8ASU1
I was able to create .stp files via the ‘Export CIS/2’ icon as outlined in Message 2 by Johnathan, but I was unable to import these .stp files into vanilla AutoCAD (refer to ‘Import Failed’ message attached). Our steel supplier informed me that he received a similar error message when trying to import the files into Solidworks. I then created .sat files as suggested by Aleck in Message 10. Our steel supplier was able to open the .sat files in Solidworks.
Message 12 of 12
Sebastian_Eiche
That's because the file extension stp described two different files.
The cis/2 file STP describes a Systemline start- and endpoint, with information for material and coating.
The Step file which you need for CATIA, SOLIDWORKS or Inventor is just a 3D Solid like an ACIS (sat file) without any information, just a 3D solid
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
