Stair Macro
Stair Macro
MahmoudMS4U8K
Stair Macro
MahmoudMS4U8K
Is there an option to offset all the stair treads vertically and horizontally, actually I can see it but only for the first and the last treads you can separate it from the other treads and change them, but I want to offset all of them.
Usually when I draw a stair; I draw it from the top of steel to the top of steel, but the risers should be divided from the finish floor level to the finish floor level, so I have to make an offset to the treads vertically with the floor finish value.
markhubrich
It takes a little messing around but it can be done. I did a post in here back in 2016 about it after I modeled three 26 story stairs with sanitary treads and Wooster nosings. It's been a long time but I'll try to dig that up shortly.
...and fix the kiss export issues.
MahmoudMS4U8K
would be greatly appreciated, thanks.
