SPIRAL STAIRS-CLOCKWISE AND COUNTERCLOCKWISE
h.kh
h.kh
Hello
 I try to use simple spiral stairs with the MC12X10.6 stringer, but it should be counterclockwise according to Architectural Drawing.
For clockwise , everything is ok. but when I make it counterclockwise the stringer flanges turned to inside of stair (is not correct) , But for clockwise the flanges are out which is right.
Is there anyway to make flanges out when it turns counterclockwise.I attached a picture.
Thankyou
múinteoir
There is no toggle for this in the macro. You can delete the joint box the mirror the section
Múinteoir
The face of the BIM game | Former Autodesk Expert Elite | YouTuber | Lego Builder | Monaghan Man | Some Can, Some Cant
h.kh
Thank you Jonathan for making it clear for me  and also the way that I can make it. was very helpful and worked.
