round plate at top of a column with holes
archtina
Message 1 of 9
archtina
How to create round end plate at top of a column with holes on it?
I have created round plate with 'plate at poly line' command, but when I try to make holes, it just doesn't work. I can only create holes on square plate.
Please help.
Replies (8)
Message 2 of 9
CHRIS_ASDL
Hi
This is possible to do. Create the plate using the Circular Plate icon in the Objects tab. Then create the Holes using the Circular Center Point feature.
Hope that Helps!
Kind Regards
Chris
Message 3 of 9
múinteoir
Use the circular contour features
Múinteoir
The face of the BIM game | Former Autodesk Expert Elite | YouTuber | Lego Builder | Monaghan Man | Some Can, Some Cant
Message 4 of 9
archtina
I still can't make holes in it.
Message 5 of 9
archtina
I tried to create circular plate, but when I clicked OK nothing happened. Is there some step in creating circular plate that I skipped?
Message 6 of 9
archtina
Sorry, I just didn't see the plate,  it was created in 0,0,0.
Your method works. Thank you.
Message 7 of 9
Sebastian_Eiche
the command circular plate is always creating a plate to the UCS 0,0,0, maybe you have now many many plates in your model? 😃
But if you want to create a round endplate, please use the automatic connection for it. Connection "Endplate" and then Layout "round":
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
Message 8 of 9
CHRIS_ASDL
Here's a screen showing the steps I took to create the plate and holes.
Kind Regards
Chris
Kind Regards
Chris
Message 9 of 9
crydee-AG1
If your column is a tube then you can use the Tube Base Plate joint in the Plates at Beam group of Connection Vault. This will create the circular plate in the right place and put the holes or anchors in accordingly. You can use the Switch Beam End box on the General page of the joint properties to get the plate at the top if it comes out at the wrong end.
Aleck Giles,
LinkedIn
Autodesk Certified Instructor - Gold
